Whites not white enough!
Re: Whites not white enough!
I know, it sounds like a laundry problem, but not quite!lol!
I've recently printed a couple of jigsaws and the whites are slightly yellowish. Could this be a heat problem or pressure maybe? Any ideas please?
to much heat??? what jigsaw are they and what settings you used for pressing?
Hi Paul. They're wooden puzzles and we're using 180deg for 60 secs. The other puzzles have come out fine, but this particular one has a lot of white in it and half of it seems a bit yellow.
when i had yellowing on my mugs i lowered temp but increased time. never had this problem on jigsaw tho.
As sublimation printing doesn't use any white - it has to be a heat issue. I think you may be scorching the jigsaw.
Is the original artowork's white actually white, or is the printer laying down some yellow?
- Has thanked: 11 times
- Been thanked: 9 times
Are you using anything in-between the transfer and the heat press? i.e. silicon sheet etc?
Justin......I use a silicon sheet underneath and a greasproof paper on the top.
pisquee......The original artwork looks white to me. If I can work it out, I'll try to post a photo of it.
Can you use the colour picker tool thingy in Photoshop to see if it is completely white?
