Novachrome Mug Press test against Xpres Mug press
Zipdorf
Re: Novachrome Mug Press test against Xpres Mug press
Post by Zipdorf »
In an attempt to find the way of producing the best quality mugs I have purchased both the Xpress (Adkins) and Novachrome mug presses. Both brand new. I have so far used the Xpress press at 180c for 180 seconds. The Novachrome instruction booklet tells me for Durham mugs it should be 365f (that is 185 centigrade) for only 30 seconds? far short of the 180 seconds on the other press.
Anyone have experience on this, please?
And what is "idle temperature", which they say should be 360f (182 centigrade)?
I am using the Ricoh 3110 printer with sawgrass inks, BMS mugs and Xpres paper (I am also going to try both with truepix paper as well).
Once I have some feedback on the above I will conduct tests and offer the results for everyone to see.
mrs maggot
Post by mrs maggot »
why not call them and ask them the supplier !!! then you can also give feedback on the customer service as well
Zipdorf
Post by Zipdorf »
Great idea and so obvious I hadn't thought of it. So I did what you suggest but they are based in North Wales and the snow has meant they have sent all the technical people home until next week.
Has thanked: 11 times
Used the twin head mug press from Novachrome and had nothing but problems, will be interesting to see how you get on. Adkins can't be beaten IMO as and is my main weapon of choice.
Expensive experiment BTW! Lol.
Post by GoonerGary »
I'm about to buy one of those two exact mug presses! Wow. I have a novachrome press from about 8 years ago and it has worked very well...still does although the blanket is creased. It cost me nearly £800 back then, trouble is that it looks like those rubbish chinese presses you see everywhere which cost £120.
Idle temperature I believe is when you are not pressing an actual mug, but you will have your press still switched on with a safety mug sitting in place instead...keeps the temperature up so that it's ready.
I have always used Trupix as it was regarded as the best, but would love to know how sharp the xpres paper is in comparison.
mrs maggot
well i guess the weather has hit some harder than others lol, is there nothing on their website ??
