print profile in elements 11
Any OS, software in here.
steve 1
Re: print profile in elements 11
Post by steve 1 »
having checked my printer settings i noticed some faults i have been on sawgrass website they only have elements 10 listed
what i have done according to there instructions is the following
in edit couler settings clicked and saved no couler management
checked that when image is open rgb couler is checked
what i cant do is in the menu bar image convert colour proflie is convert to srgb the convert couler profile is grayed out
i have just printed another mug again no fading but the dark hair on my dog is coming out light like orangy even though on paper it is dark brown is this temp or print settings
do you use powerdriver steve?
steve 1
Post by steve 1 »
yes paul i have turned of couler managment set image has rgb when printed in ceramic get nice clear image bot brown is orangy if i print in subli products i get get correct couler but blurred just spoke to martin he has very kindly offerd to print a mug if i send him an image but is printer is out on demo so it will be next week which is very good of him
but if you use powerdriver then you dont need to change anything in color management as powerdriver is the thing that do that for you. I think...
RogerC
Post by RogerC »
Paul;63255 wrote:but if you use powerdriver then you dont need to change anything in color management as powerdriver is the thing that do that for you. I think...
Correct Paul.......powerdriver does it all for you.
JMugs
Has thanked: 9 times
Post by JMugs »
Can't comment on Elements, but I use CorelDraw and I don't change any settings. just print through Powerdriver. Just a thought, can you post your image to somebody on your paper for them to print on a mug. If it works for them you either have a press problem or mug problem. Send them a couple of pounds worth of stamps at the same time to cover the cost of a mug and some time. The closer to you the better, as it gives you somebody to chat to on the phone as well, catch up for a coffee, beer etc.
viccar
Post by viccar »
See this is what confused me in the begining, it says follow instructions
here http://www.sawgrasseurope.com/technical ... winprofile
then here
http://sawgrasseurope.indigofiles.com/t ... -10-WP.pdf
Then after going on here i ignored all of that ^^ and just used power driver.
steve 1
Post by steve 1 »
after instaling the powerdriver from sawgrass it then asks you to configure your graphics programme there is a list including elements and coral thats how i read it unless iam misreading it
steve 1
Post by steve 1 »
thank you viccki i did read it right then lol
steve 1
Post by steve 1 »
would a picture of the 2 mugs side by side help
