T-shirt transfer - contour cut from start to finish! (2nd video)
FairyD
Re: T-shirt transfer - contour cut from start to finish! (2nd video)
Post by FairyD »
Another great video Paul, thank you. Question......what kind of t-shirt did you do use?! Just visited the Yolo site and they claim you can use their paper on Cotton or Poly blend t-shirts!!
I used 100% cotton shirt. FOTL i think. need to have a look.
arko
Post by arko »
Cheers once again Paul... I was able to see the controls on your laptop this time to understand better what you were actually doing to move the cuuter head.
Thanks! :)
GoldRapt
Has thanked: 6 times
Been thanked: 7 times
Post by GoldRapt »
Excellent video paul, I must say the screen key moving the blade about part is very fiddly with my machine.
One question that is buggging me though, you must have seen my post in the Yolo thread, in the video you say your instructions are cold peel.
I have exactly the same paper and my instructions say Hot peel. I wonder if that is part of the problem I am having. Can you check your instructions and confirm they say cold peel please?
regards
Tony
-launching july/august 2026
Will do. But from memory i think cold peel will give you matt finish and that what i was after.
GoldRapt
Post by GoldRapt »
Thanks Paul, I am just trying to work through my issues.
regards
Tony
Ali P
Post by Ali P »
GoldRapt;77842 wrote:Thanks Paul, I am just trying to work through my issues.
Hi Goldrapt,
Jetpro Softstretch is hot peel but as you can see from this link, waiting until it is cold gives a different finish:
http://www.yolo.co.uk/jet-pro-sofstretc ... er-2-p.asp
There is a section within the site to download PDF instructions (noting some are iron instructions and some are heatpress)
I use this paper and it is great and is most successful longterm if you stretch it whilst warm (after peeling) and repress gently for a few seconds with a silicon sheet over it.
GoldRapt
Post by GoldRapt »
Hi, yes I do all that. But I still have a yellowing problem in the "self weed" area's.
regards
Tony
GoldRapt
Post by GoldRapt »
PAul, what settings did you use for the cutter please to cut such a thin layer?
regards
Tony
