Page 1 of 2
Re: Vinyl cutting software
Posted: 13 Jan 2013, 20:39
by Ricky
Hi guys
i have purchased a vinyl cutter about a year ago (expert 24) and have not really got around to using it. I am just wondering if anyone knows of any cutting software for this?
Ideally something which will work with a mac.
Posted: 13 Jan 2013, 20:43
by Paul
flexi 8 will work on mac.what is name of your cutter?
Posted: 13 Jan 2013, 20:57
by Ricky
Ignore the mac software just found out the gcc expert 24 is not compatible!! looks like I will have to dig out my old pc!! I just need some software which is simpler to use than coral
Posted: 13 Jan 2013, 21:00
by Paul
why not?? :confused:
Posted: 13 Jan 2013, 21:03
by Ricky
Don't think the drivers are available by the looks of it.....
Posted: 14 Jan 2013, 14:13
by RogerC
Ricky;62898 wrote:Ignore the mac software just found out the gcc expert 24 is not compatible!! looks like I will have to dig out my old pc!! I just need some software which is simpler to use than coral
Ricky I don't know how much experience you've had with Corel but I find it quite easy to use in my 'limited' capacity. I started using it about 3 years ago and at that time found it almost impossible to use however with time I now find it great. Sizing, insetting images in shapes, cropping and most of all adding cut lines are now easy. I would recommend you stick with it because it will pay dividends in the end.
Posted: 14 Jan 2013, 14:57
by Ricky
Ok great I will try and plod on with it, it's hard trying to find online tutorials on actual vinyl cutting using coral but I will have to sit down and play
Posted: 14 Jan 2013, 15:15
by newsgroupmonkey
Funny enough, I've tried loads of different software. I'm using signblazer (there's a link to it from the USCutter site).
I just couldn't get Corel working properly for my cutter (Pixmax)
Signblazer is a bit ronseal really - it's very basic, but it does exactly what I want and it's free!
edit: to add to the post below, I have already got my images into Vector format. I just use SignBlazer for the cutting.
Posted: 14 Jan 2013, 15:19
by Earl Smith
Try these Ricky.
http://advancedtshirts.com/tutorials.html
http://www.advancedartist.com/coreldrawtutorial.html
http://www.entheosweb.com/tutorials/cor ... 3mHhtnG0rU
and there is another site posted on here by Mrs Maggot.
These are all vector tutorials, not specific for vinyl cutting. Im sure if you look on youtube you will find some vinyl ones on there.
Posted: 14 Jan 2013, 15:27
by Renniwano
I use Corel with a Signcut Pro plug in.. not sure if it would be available for your machine but even I manage to use it ;) so it can't be that bad lol
