Blackberry Torch 9800 this time.
Print fine but anyone else find the metal does not fit the case proper at the bottom ? . kinda asking to be pulled off in someones pocket - even with a couple of spots of the old superglue :rolleyes:
need to buy some more of them as i run out so will see how the next batch are.
Another Blackberry Case
Re: Another Blackberry Case
I have the same problem with them, just takes a bit of squeezing together. I was thinking about removing them from my site
Matthew
aye posted elsewhere mattie - refunded customer and taken them off my site and ebay store as well.
Quality and fit not up to scratch for me anyway. And ONLY available from one supplier - and they are more expensive - more expensive and a crappier case -
and
there aint that much of a market for them.....done and binned.
and
They can be quite tricky, i get mine from abroad, I've found them quite popular.
I quite like the slide bit that clips to the front to
Matthew
Mattie;62755 wrote:They can be quite tricky, i get mine from abroad, I've found them quite popular.
they are a nice case granted - but i also got stung with the first one for p&p - should have been 2nd class 0.69p - because it was a thicker case, and always use bubble wrap around phone for extra protection, i got stung for 2nd class £2.20 large pkt :rolleyes:. cause the nice lady says it wouldnt fit through the slot she had :rolleyes:
learned from that one as well
