Bought this in September last year but unable to get on with it not what i thought it would be like to use. Sublimation T-shirts and other items is not for me. This is New Used to press two t-shirts.
http://www.coralgraph.com/heat-press/combo-heat-press/heat-transfer-press-combo-mug-t-shirt-plates-cap-8-in-1
New 8 in 1 Combo Press . Heat Transfer Press Combo Mug T Shirt Plates Cap 8 in 1 2xPlates+4xMugs ,Large Flat T Shirt Press 28cmx38cm +Cap 1. Wrap around, All metal construction. 2. Digital temperature adjustment, Digital timer, Automatic constant temperature. Special silica gel mat makes the pressure more even 4. Self-adjusting pressure device. 5. Easy Heater Replacement. 6. Brand new and modern design 7.Comes with a full instruction DVD how to use heat press,easy for beginners Specification: Temperature Range:450W - 1200W Timing Range: 0-999 Sec. Voltage: 220V-250V,50HZ Power: 450W Fitted with 13 Amp Fuse Packing size: (1)52X48X50Cm (2) 35x24x30cm Net Weight: 43 Kg 4 different size mug heating mat (Diameter:12oz,17oz for latte mug, 5-7.5cm, 7.5-9cm for mug ) two plate mats.( 12cm and 15cm) cap press 80x150 mm t-shirt press 28x38cm.
Also some sublimation blanks that were sent FOC will be included.
Cost £374.99
Collection only
£250.00
Will issue a invoice on sale (not vat)
Corolgraph Heat Transfer Press Combo Mug T Shirt Plates Cap 8 in 1
