pressure
steve 1
Re: pressure
Post by steve 1 »
hi guys
Thanks to a very prompt supplier my mug press and printer etc arrived today iam keen to set up and have a go ha ha. i would be gratefull if anybody can tell me prior to pressing is there any tell tale signs that the pressure is incorrect because i have read about possible problems if presure is wrong or is just experiment and gain experiance
thanks steve
Re: pressure
It should be tight enough around the mug so that the heat blanket curls slightly over the top and the bottom.
steve 1
Re: pressure
Post by steve 1 »
Thanks justin appreciate that will check that bit out
Re: pressure
No worries, it'a trial and error but you'll probably find it's quite a heavy pressure.
viccar
Re: pressure
Post by viccar »
Put your mug in the mug press without it being turned on and experiment with the pressure a bit.
Then when you think its about right turn the press on and try.
Once it feels about right then it should be ok for you mu its a bit scary the first time it seems hard, and feels like the mug might break.
steve 1
Re: pressure
Post by steve 1 »
thanks for that never had one before so dont know what it should feel like but i agree it feels a bit scary ha ha
mgibbs
Re: pressure
Post by mgibbs »
If the mug comes out smaller than it went in then the pressure's too high :)
I have mine set so it's just tight enough to stop you being able to turn the mug while it's clamped.
Mark
steve 1
Re: pressure
Post by steve 1 »
thanks mark i have not checked mine over proper yet has i only got it today but i think from memory it clamps right up to the handle on mine i will have a proper look tomorow
Charlie_
Re: pressure
Post by Charlie_ »
mgibbs;62170 wrote: I have mine set so it's just tight enough to stop you being able to turn the mug while it's clamped.
Mark
I have mine set the same.......... no problems with pressing
Re: pressure
steve 1;62175 wrote:thanks mark i have not checked mine over proper yet has i only got it today but i think from memory it clamps right up to the handle on mine i will have a proper look tomorow
Make sure that the mug itself is actually clamped tight, and it isn't the handle that is too big and taking all the pressure - we have some mugs which won't work in a couple of our presses due to the handles being too wide.
