t-shirt transfer paper - contour cut with out optical eye.
Re: t-shirt transfer paper - contour cut with out optical eye.
Excellent video Paul...... I have been banging my head trying to figure it out on my cutter. Many thanks. Off to give it a go now!
Thanks for the video Paul sure does help clear the air about those red eyes
Dave271069
hi paul, nice video again, what transfer paper you using?
thanks guys!!!
paper i used is JetPro Soft Stretch. best paper for white garments i ever used. didn't used that many but this one is my favorite so far!
- Has thanked: 11 times
- Been thanked: 9 times
Very interesting Paul, pretty much same cutter as mine although the red led disappeared on mine ages ago! lol.
I'll have to give this a go, I knew there was a way but I've never seen it done, many thanks for posting
No problem JUstin!
all you need to do is press down the knife to see if it points in the middle of the reg mark. if it does then you move forward to next reg mark. You need software that let you contour cut tho...
As you can see on video its pretty accurate and great was to cut transfers if you dont have expensive machine. bit time consuming so i would not want to cut 100's transfers lol but for few offs its good.
EXCELLENT VID for those without the optical eye paul.
Sure to help many peeps on here - 10/10 again bud
Thanks for the video Paul, nice one.
Nice artwork too.
Nice artwork too.
Good video Paul, can you tell us the right contour cut software to use?
