Hello,
Having trouble with print quality. I'm printing black on to white and after it's printed I'm left with 2 feint (but still visible) lines running vertically through the design. I'm sure it's from residual ink left on the rollers, but not sure how I clean them. I've cleaned and flushed the heads/nozzles but that hasn't solved the problem. Any suggestions?
lisa
Ricoh 3300 cleaning
- WorthDoingRight
Re: Ricoh 3300 cleaning
Well if it is on the rollers or path then you could try my method which is to just send an A4 document to the printer with just a single full stop on (so pretty much a blank sheet) using cheap white paper and repeat until it clears (if it is going to then you should see a difference after 10 sheets)
carter2
This problem is found in many Ricoh pirnters..:frown:You can just simply open the print tray and clean it with the spray or cleansing kit given to you and if it persist just simply re-install the software again..
carter2
This problem is found in many Ricoh printers..:frown:You can just simply open the print tray and clean it with the spray or cleansing kit given to you and if it persist just simply re-install the software again..
Users browsing this forum: No registered users and 13 guests
