Whoo hoo cant wait
- WorthDoingRight
Re: Whoo hoo cant wait
Well good luck when it arrives and all I will say is read the instructions and take your time setting it all up - 'fail to prepare and prepare to fail'
Good luck with everything Vicki & if you need any help then you know where to find us :biggrin:
well im glad you said that Ian because......
on reading http://www.sawgrasseurope.com/technical ... winprofile
it says
. Configure your design software. Select from the applicable list below for complete instructions.
now i only have elements ver 7, inkscape, gimp 2 and studio designer edition. Does that mean it wont work with any o
it says
- CorelDRAW 12, X3, X4
- CorelDRAW X5, X6
- Adobe Illustrator CS5
- Adobe Photoshop Elements 8,9, 10
- Adobe Photoshop CS, CS2, CS3, CS4, CS5
The Ricoh use Powerdriver which enables you to print from any graphics package
You need to go here:viccar;58743 wrote:well im glad you said that Ian because......
it says
- CorelDRAW X5, X6
http://www.sawgrasseurope.com/technical ... wer-driver
1. Install the Ricoh driver & PowerDriver.
2. Download and review the PowerDriver driver User's Manual:
[LEFT]3. Configure your design software. Select from the applicable list below for complete instructions.[/LEFT]
which says the same thing version 8,9,10, thats whats confusing me.
- Print Setup Guide - CorelDraw 12, X3 & X4
- Print Setup Guide - CorelDraw X5 & X6
- Print Setup Guide - Photoshop CS, CS2, CS3, CS4 & CS5
- Print Setup Guide - Illustrator CS5
- Print Setup Guide - Elements 8, 9 & 10
