apologies for my absence - I had to take some time away due to unforeseen circumstances, but I thought I would update everyone on the problem I had on my last visit to the forum (regarding this post: http://www.dyesubforum.co.uk/vbforum/sh ... pson-B1100 ).
To refresh - I had problems with prints on my b1100 which resulted in blocked nozzles and print outs that could not be used. I had tried many things from replacing the refillable cartridges, filtering the ink through a gauze (a pair of tights) and giving the system a good clean with 'unblocking' fluid - all to no avail.
The printer in question was only 2 months old and because of this I approached the company I had purchased it from, who stated that the warranty was void due to using a ciss system!
This was the second (b1100) printer that had problems and to be honest, I did not need (or want) the cost of replacing the system again (I was using a b1100 as I had the supported set up and inks from Sawgrass).
I then emailed Sawgrass one Sunday night, really for advice and where I could get the printer serviced and was very, very surprised when I had an email back within a couple of hours asking for more details.
What followed then were numerous emails and calls from a gentleman called Nigel Reeve from Sawgrass, who asked for confirmation of the system I was using and where I had purchased it from.
Nigel confirmed that my issue could not be pushed any further with the original supplier of the printer as they were correct in what they had said and the Epson Warranty was invalid due to using a ciss system. Sawgrass, however, do give a warranty for the ink delivery system (where my problem lied) but they were concerned that the printer in question was not purchased from a registered seller and from somewhere else.
I explained at great length that the printer was a replacement for one purchased from a registered Sawgrass seller and they (the supplier) were my first port of call to get a replacement printer - but I was informed that this could not be supplied by itself and was out of stock anyway as the b1100 support is a 'dis-continued' printer (i.e another printer has now taken its place). This was no good to me as I had all the drivers, supported ink and profiles, so I had purchased another b1100 to enable me to carry on using supported ink - this replacement printer was the one that had gained another blockage (the same as the one previous purchased with the set-up).
Sawgrass said that they would look into providing a replacement printer but were having great difficulty in finding one. They asked if I was interested in moving onto the newly supported 'closed cartridge' system and offered to provide me with a full ink system if I purchased the printer.
I explained that I would 'probably' move onto a new system but I still had a great deal of ink left for the b1100. I asked if I could also look into getting a replacement b1100 to which Nigel informed me that whichever system I decided on - they would provide a new ink system for it.
I emailed epson direct to be informed that I could get a refurbished b1100 printer direct from epson for £85 which included VAT and delivery - I ordered one, had it 24hrs later and informed Nigel at Sawgrass that I was back up and running. A new ink system was sent to me (complete ciss system with full inks) and I sent any inks back to sawgrass that were left. The ink was (requested to be) sent back for a couple of reasons, firstly to avoid any further contamination problems that could have been caused by the ink I had and secondly (and most importantly) to show (and prove) that I was indeed using a supported ink system (and inks) - although I had sent photographs in previous emails.
Now, I am back up and running - still with a b1100 and still with supported ink (artainium sawgrass sublimation ink) and everything looks great.
The morale of this story is that yes, inks are available that are not supported and yes, I know that many people have created their own profile for these inks and use them successfully (although this is not part of the post - and unsupported inks should not really be discussed) - but, you could probably guarantee that 99% of those using unsupported inks have some experience in sublimation.
:biggrin:Why do I mention experience? I do so because going the 'un-supported' route means exactly that and finding your own path means walking alone - without the support. I chose the path very early on to use a supported system and inks which paid dividends to any problem(s) I had that were sorted and solved very, very professionally by Nigel at Sawgrass.
If you are not sure which path to take then asking that question surely means that you may not be able to 'problem solve' any errors along the way - and if you are not sure which path to take then there really is only one route - the supported way, where this post proves that a 'supported' system really means what it says on the tin 'support'.
Many thanks to Nigel at Sawgrass who was truly outstanding in helping me with this problem - second to none in support and top marks to Sawgrass
