Picture won't fit for iPhone case
Dave271069
Re: Picture won't fit for iPhone case
Post by Dave271069 »
I have been sent a picture of a baba for someone to have on a iPhone case. The problem I have is the babies head is at the top of the picture which would be right where the camera hole is, how can I adjust this, there is no more picture above the head.
Is there background around the pic? If you could show us the pic it may help. Initial thoughts are that the area may be cut out from the background and printed lower on the case.
Dave271069
Here is the picture, ta
vB_ID:1263
vB_ID:1263
Difficult to lose anything on that pic really. I know the template size you're working with is quite long and thin, maybe put a border or frame around the image? Uhm, doesn't sound great and photo may still be a little small.
RogerC
Post by RogerC »
Try cloning the top strip of the photo and attach it to the top of the picture. I tried it in Corel draw (photoshop will also do this) and it gives you more 'background' which effictively moves the baby lower in the pic away from the camera hole.
Ian M
Post by Ian M »
Dave, I've just had a try & got the picture to fit & wondered if this would be ok.
[ATTACH=CONFIG]1264[/ATTACH]
vB_ID:1264
vB_ID:1264
iPhone4 Baby.jpg (20.65 KiB) Viewed 190 times
There has to be a compromise somewhere and I think that's a great solution here Ian.
Dave271069
Cheers Ian, looks ok to me,will have to see wot customer thinks
