Re: Vignette effect using Photoshop
Posted: 18 Oct 2012, 09:57
by R.Prints
I am using an old version (Photoshop 2) and can't figure out how to apply the vignette effect to a picture. Keeps telling me " a selection is required " but I can;t figure it out. Old version but does everything I need it to do, well almost!
Ray
Posted: 18 Oct 2012, 10:08
by socialgiraffe
The selection tool is the second button down on the floating tools bar.
From what I can figure out by your message Photoshop needs to know where you want the vignette applied. Using the selection tool, click and drag over the area you want to vignette, one you are satisfied with the are indicated by the moving dashed line, click on the vignette tool and awa you go.
The above is only what I think it could be by the way. Can't remember that far back :-)
Posted: 18 Oct 2012, 11:29
by Paul
Yep. Also you can use sellection circle tool to do it niceley :-)
Posted: 18 Oct 2012, 13:45
by R.Prints
Simple when you know how. Cheers folks.
Posted: 23 Oct 2012, 13:35
by Andrew214
I am agree with socialgiraffe. One thing is important that, where you want the vignette applied. Just use the selection tool, click and drag over the area you want to vignette.R.Prints, if you are not understand then you need to use tutorial.
Posted: 23 Oct 2012, 16:04
by JackB
Try http://picasa.google.co.uk/ It's a free picture editor and has quite a good and easy to use vignette tool.
Jack.
Posted: 24 Oct 2012, 10:49
by R.Prints
Cheers ac2,
Posted: 24 Oct 2012, 11:09
by R.Prints
Forget last, finger trouble. Have download now just need to figure out how it works.
