Re: heat press temp guide test
Posted: 12 Oct 2012, 14:08
Last night I went to see another member on this forum as they were having problems with pressing transfers. Turns out that this particular problem was located between the floor and the handle of the press so all good, but we both thought the following post would be a good idea.
For this exercise you will need a heat press, 5 minutes of your time and an infared temperature guage.
Basically I am trying to see what the differences are between heat press machines and also the variances on each platens. To be able to do this we need to all measure to a set standard as instructed below.
Set the temperature of your heat press to 180 degrees (sorry I don't do F)
Measure the temperature at each corner and then in the center
Measure from a distance of approximately 2 inches from the platen
Post your results PLUS the make and model or weblink to the particular heat press you are using.
I am hoping that we will get a load of posts and will be able to see if the Adkins of this world are more accurate etc. and be able to build up a better and more informed opinon on what is good and what should be avoided.
Here are my results to start the ball rolling:
Heat press: http://www.printerowners.co.uk/hardware ... -press.htm
Measurements: Corners: 177; 177; 175; 175. Center: 182
Variance: 175-182 = 7 degrees
I have no idea if the above is good, bad or indifferent so it would be great to see as many results as possible
