I can use 3mm silicone sheet but thought I'd ask if anyone knew where to get the proper material first
Lower platen mat
- Has thanked: 11 times
- Been thanked: 9 times
Re: Lower platen mat
Anyone know where I can get the material used for the bottom of the heat press to put onto a new platen?
CG buddy! Dont know what size you need but have a look on here: www.coralgraph.com/heat-press-accesorie ... rkhh5qeir4
- mrs maggot
let me know what you stick it on with please justin, i have tried several glues, but none want to stick too well
Gone for the cg option. Spoke to Adkins but theirs are around £60, self adhesive backing. I might just leave it loose otherwise I'll find something that will withstand high temps
I have a press from CG with the large 'rubber padding' base and it's not stuck down.. should they be ?? lol
- mrs maggot
on my geo knight its stuck down, on my other big press its not, i find that hoodies and things catch on it and pull it up - so my pref is for sticky
Mine doesn't move.. BUT saying that do have the issues with Hoodies as Mrs Maggot.. sooooo do I stick it down lol that is the question !!
