Photoshop
Any OS, software in here.
SilentAlf
Re: Photoshop
Post by SilentAlf »
Hi All,
Does anyone know if you can make a boarder/template using photoshop to fit the size of a mug, so if i had a photo i could drag it over the template and the photo would automatically adjust fit to size?
Re: Photoshop
Iam affraid there is no point o doing this.
Ig uour templat will be 300dpi and your picture 72dpi, picture will be enlarged and pixalated...
An another thing this is not only template but you will need action to do that for you...
Russ
Re: Photoshop
Post by Russ »
It's not an auto-resize, but I use a 20cm x 9cm blank doc then File>Place the pic on to it. It will appear on a separate layer with the resize control handles ready for resize / reposition.
Andrew214
Re: Photoshop
Post by Andrew214 »
I have good knowledge about adob photoshop. But i am not understand with you what are you saying?
