edible printers
Re: edible printers
been thinking about doing edible cake toppers.
a friend is a chef and is a stay at home mum so can't work reg hours so i thought about teaming up with her to do personalised cakes
anyhow anyone got any recommendations for edible ink printers?
A4 or A3 etc canon or epson
thanks steve
thanks steve
Re: edible printers
I read some about this.years a go and most of the time canon was mentioned. Inks are cheap so wortho have a go i think
if you know someone who bake cakes then nothing to lose
Re: edible printers
I know BMS do a range of printers and edible ink..
Re: edible printers
i think the common cake size is 9" so i think it'll need to be an A3 printer
these aren't cheap annoyingly
Re: edible printers
I know nothing about them, but if you need any help with samples send them down here and I will happily comment on the print quality as long as it is attached to the bottom part
- WorthDoingRight
Re: edible printers
Well if the cake is outside 9" then I am sure an A4 printer would do as the topper doesnt normally go right to the edge. It does seem that Canon printers tend to be favoured.
Re: edible printers
good thinkingWorthDoingRight;55186 wrote:Well if the cake is outside 9" then I am sure an A4 printer would do as the topper doesnt normally go right to the edge. It does seem that Canon printers tend to be favoured.
- WorthDoingRight
Re: edible printers
Now here is my favourite edible printer:
[ATTACH=CONFIG]1218[/ATTACH]
- vB_ID:1218
- cake1.jpg (64.17 KiB) Viewed 421 times
Re: edible printers
Steve, I would have a chat with Martin at BMS as they have been supplying all the things you would need to be able to do this. Good luck with the venture mate & hope it all goes great.
Re: edible printers
I can see that already. Steve puting some wight on
