Page 1 of 6
Re: Right - that's it, I have OFFICIAL had enough of this epson B1100
Posted: 26 Sep 2012, 15:14
by AdamB
To be honest - I haven't been around for a bit as I'm trying to chase as much business as I can (which in these days is quite hard).
So - it doesn't help with this damn b1100 clogging!
I had a problem about 2 months ago using a ciss system so I bought a NEW b1100 and used refillable cartridges - everything was fine until the start of the week and now I started with a problematic blue to then lead onto all colours blocked in some degree.
I had some cleaning solution that I bought off ebay so used this overnight and ran it through the head a few times and now it's still blocked on a nozzle check (all colours in some degree) and shows as lines on any print outs.
Now, I have ran out of black ink so more's on order together with a different cleaning solution just in case the last one had a shelf life!
GIVE ME STRENGTH I can't even chase business or take any orders now!
Sorry - it was either whinge and wine on here or give the missis both barrels and she has hairier arms than me so forgot that one!
Posted: 26 Sep 2012, 15:28
by WorthDoingRight
To quote that immortal line from 'I married an axe murderer' - 'Hey, somebody needs a hug' lol
Posted: 26 Sep 2012, 15:30
by AdamB
WorthDoingRight;54648 wrote:To quote that immortal line from 'I married an axe murderer' - 'Hey, somebody needs a hug' lol
Not a hug buddy - just workable equipment........
...........Hey, i'd hug a horse right now if a fairy would fix my problems!
Posted: 26 Sep 2012, 15:42
by WorthDoingRight
Well, I wish I had a magic wand but other than saying try the 'clear' windolene to clean the heads or wait till the other cleaner arrives.
I expect to be pulling out my hair in frustration this weekend as I will probably need to clean the heads on a secondhand wide format printer and maybe the ink path before I can see if it works.
Posted: 26 Sep 2012, 15:51
by pisquee
What ink you using in the 1100?
Posted: 26 Sep 2012, 15:55
by AdamB
pisquee;54656 wrote:What ink you using in the 1100?
Artainium Sublimation ink - always used this to be honest right from the start.
(remember - we can't talk about 'other' sublimation ink)
Posted: 26 Sep 2012, 15:58
by Andrew
I've always got ink and just 20 or 30 minutes down the road from you if your ever desperate.
Posted: 26 Sep 2012, 16:00
by AdamB
Andrew;54659 wrote:I've always got ink and just 20 or 30 minutes down the road from you if your ever desperate.
Andrew - you are a true gentleman - thank you :)
I've got some coming tomorrow (hopefully) and to be honest I'm going home at 5pm as I've been in the shop till 2am the last 2 nights trying to sort this problem out and get other orders out - hopefully it will be sorted ............... hopefully!
But - like I said, thank you for the offer buddy, really, really appreciated :)
Posted: 26 Sep 2012, 16:03
by Andrew
Not a problem. The offer is always there for any bits and pieces or prints etc that you might need when under pressure.
Good luck with it.
Andrew
Posted: 26 Sep 2012, 16:06
by AdamB
Andrew;54662 wrote:Not a problem. The offer is always there for any bits and pieces or prints etc that you might need when under pressure.
Good luck with it.
Andrew
Thanks buddy :)
