Right - that's it, I have OFFICIAL had enough of this epson B1100
Re: Right - that's it, I have OFFICIAL had enough of this epson B1100
To be honest - I haven't been around for a bit as I'm trying to chase as much business as I can (which in these days is quite hard).
So - it doesn't help with this damn b1100 clogging!
I had a problem about 2 months ago using a ciss system so I bought a NEW b1100 and used refillable cartridges - everything was fine until the start of the week and now I started with a problematic blue to then lead onto all colours blocked in some degree.
I had some cleaning solution that I bought off ebay so used this overnight and ran it through the head a few times and now it's still blocked on a nozzle check (all colours in some degree) and shows as lines on any print outs.
Now, I have ran out of black ink so more's on order together with a different cleaning solution just in case the last one had a shelf life!
GIVE ME STRENGTH I can't even chase business or take any orders now!
Sorry - it was either whinge and wine on here or give the missis both barrels and she has hairier arms than me so forgot that one!
- WorthDoingRight
To quote that immortal line from 'I married an axe murderer' - 'Hey, somebody needs a hug' lol
Not a hug buddy - just workable equipment........WorthDoingRight;54648 wrote:To quote that immortal line from 'I married an axe murderer' - 'Hey, somebody needs a hug' lol
...........Hey, i'd hug a horse right now if a fairy would fix my problems!
- WorthDoingRight
Well, I wish I had a magic wand but other than saying try the 'clear' windolene to clean the heads or wait till the other cleaner arrives.
I expect to be pulling out my hair in frustration this weekend as I will probably need to clean the heads on a secondhand wide format printer and maybe the ink path before I can see if it works.
What ink you using in the 1100?
Artainium Sublimation ink - always used this to be honest right from the start.pisquee;54656 wrote:What ink you using in the 1100?
(remember - we can't talk about 'other' sublimation ink)
I've always got ink and just 20 or 30 minutes down the road from you if your ever desperate.
Andrew - you are a true gentleman - thank youAndrew;54659 wrote:I've always got ink and just 20 or 30 minutes down the road from you if your ever desperate.
I've got some coming tomorrow (hopefully) and to be honest I'm going home at 5pm as I've been in the shop till 2am the last 2 nights trying to sort this problem out and get other orders out - hopefully it will be sorted ............... hopefully!
But - like I said, thank you for the offer buddy, really, really appreciated
Not a problem. The offer is always there for any bits and pieces or prints etc that you might need when under pressure.
Good luck with it.
Andrew
Good luck with it.
Andrew
Thanks buddyAndrew;54662 wrote:Not a problem. The offer is always there for any bits and pieces or prints etc that you might need when under pressure.
Good luck with it.
Andrew
