15oz El Grande
Re: 15oz El Grande
HI guys! will 15oz El Grande mugs fit in standard press? i understand that i wont be able to do full print but i wonder if i will be able to close my press :)
Got to order couple of things from Martin tonight and wondered if they can be any use for me as I have a great Idea for present for VERY LARGE man :)
Reg
Re: 15oz El Grande
Post by Reg »
They should be alright they only 3 mm bigger in dia.
Re: 15oz El Grande
so i am going to get some then :)
thanks!!
accdave
Re: 15oz El Grande
Post by accdave »
We have to slightly slacken the press but they fit
bigj2552
Re: 15oz El Grande
Post by bigj2552 »
fit and print fine paul - i can do a full top to bottom print on my mug press from BMS with the 15oz.....you will need to adjust your pressure as the 15oz is thicker than the 10oz
Re: 15oz El Grande
thanks for that!
I presume temp stays same as with 10oz?
bigj2552
Re: 15oz El Grande
Post by bigj2552 »
Paul;54056 wrote:thanks for that!
i use same temps as the 10oz mugs from BMS and they come out perfect....like i said, you WILL need to release some of the pressure to get the dam thing to fit...these are really big buggers lol
Re: 15oz El Grande
nicccceeeee :wink:
i will be ok with pressure. its only temp that was worry me as i never done them. and i ordered only 6 of them so dont want to mess up to many lol :P
jennywren
Re: 15oz El Grande
Post by jennywren »
Sorry if I jumping your thread but I was going to ask if there was a seperate mug press, for beer steins and the 15oz mugs as well.
bigj2552
Re: 15oz El Grande
Post by bigj2552 »
Paul;54058 wrote:nicccceeeee :wink:
but....as you know...not all machine perform the same paul.....these are for my mug press from BMS....yours might just be a little differant...but you wont be far out if any
