Hi can anyone tell me which vinyl i need to purchase to make stencils for glitter tattoos with my cameo??
Im assuming u can do it, as looks like thats how they are made?
thanks
tattoo stencils?
Re: tattoo stencils?
Not sure about using vinyl, something like this may be of interest?
http://www.themagictouch.com/tattoo.html
hi thats for normal tattoos, i need thin vinyl stencil with backing?? then they are peeled and applied to the skin and u use body glue and apply the body glitter then remove the stencil?
my daughter does them but i am sure i must be able to cut the stencils for her as she pays a fortune for them, she would also then be able to design her own?
I am hoping this is possible with this machine , which incidently is still in its box, as im still researching all the fab things i can do with it. But def am hoping i can do the tattoos.
thanks
thanks
- WorthDoingRight
I would suggest that as you want to be able to pull it off easily you would want low tac vinyl so maybe like this although you would need to cut it to fit http://www.mdpsupplies.co.uk/aslanmattremovable.asp
oh fab thankyou so m uch, ive ordered some so will see how it works.WorthDoingRight;50512 wrote:I would suggest that as you want to be able to pull it off easily you would want low tac vinyl so maybe like this although you would need to cut it to fit http://www.mdpsupplies.co.uk/aslanmattremovable.asp
im loving this forum, its so helpful to me as a newbie
im sure i will have lots more questions once i get this m,achine out of the box and start p;laying, so thank you all for all your help xx
