European Mugs - Discount Code for Members
Re: European Mugs - Discount Code for Members
As Mothers Day and Easter are rapidly approaching we are offering 10% discount on our most popular sublimation mug - the European Mug. If you haven't had these from us in the past then they stand about 92mm tall, 80mm in diameter, white, straight sided RN coated dishwasher safe/proof. They are sold in cases of 36 and each mug is individually wraped in bubble packaging inside the box and each mug is separated by cardboard in the box in 3 layers of 12 each - these won't arrive damaged!
The discount runs from now until midnight on Friday 12th March and the link for the mugs is:
http://www.printerowners.co.uk/sublimat ... on-mug.htm
These mugs fit perfectly in our polystyrene postal boxes if you are sending by post or we also have white or brown mug gift boxes.
Oh, almost forgot the discount code ;) . At the checkout please type in 3F45C in the Discount Code section and the cost will be reduced for you. As a supermarket says - "every little helps..."
John G
Post by John G »
Hi Martin - have you done this right - it seems to be making it more expensive by about £3 odd ;)
:oops: Sorry just me getting my sums wrong again :oops:
Thanks for this offer Martin
Yes I think it's working fine. I've just added 3 cases of mugs to a dummy order and it discounted the order by 10%.
Don't forget the carriage is added but this is shown separately on the order confirmation paper - you should see order value, then carriage, then discount, then sub total after discount is deducted, then vat on the discounted order value and then final total.
AJLA
Post by AJLA »
Have been using these for a while now and would reccomend them for straight sides and never a broken one either.
accdave
Post by accdave »
AJLA wrote:Have been using these for a while now and would reccomend them for straight sides and never a broken one either.
I agree with you totally :D
