Printing on High Viz vests
Discuss other print methods.
AJLA
Re: Printing on High Viz vests
Post by AJLA »
Does anyone do this? We are often asked and I have seen them printed, I was wondering about the reflective areas, I thought you couldnt iron that area so it would be difficult to keep away from the heat under a press.
smitch6
Post by smitch6 »
i have subbed them before but i always use greaseproof on top and never had a problem.
they sub really well :)
AJLA
Post by AJLA »
The reflective area went under the press too? Under the greaseproof of course.
What temp did you sub it with I may do that actually instead, probably better than vinyl.
smitch6
Post by smitch6 »
tbh i can't remember lol
it was ages ago i did some, i did a load for my work when i was on the boat.
they cost pennies so prob worth getting a couple extra and have a test with one.
sorry :)
letsgo
Post by letsgo »
I just done a dozen today,used 200 degrees for 50 seconds.
They came out awesome customer was that happy with result hs ordered another 20,they used to get them with flex print but have now request sub means easy work for us and same profit .
Gary
Jason
Post by Jason »
I've found they sublimate very well but because you or going onto a green/yellow or orange vest the colours don't come out as expected these days I only sublimate black designs any colours I use flex. The reflective areas are fine under the press providing you use a teflon sheet or as us cheapskates prefer greaseproof paper, this is essential as the dye does come out the vest under the press.
logobear
Post by logobear »
I HAVE USED LASER TRANSFERE, sub, AND VINYL, ALL FINE, YOU CAN PRESS RIGHT OVER THE REFLECTIVE MATERIAL.
You can also cut & press reflective.
No issues on them.
ptholt
Post by ptholt »
As the nights are drawing in and the clocks about to go back am looking at this, but i am surprised that sublimating would be cheaper than vinyl?
Are we sure about that? The cost of sub paper, ink, print costs compared to purchasing vinyl and cutting it...
I would have thought more expensive to sub surely?
Second thought was having only ever subbed white items, so you need special vests for sub or because they are poly it works ok?
