Exact ink level
mugstar
Re: Exact ink level
Post by mugstar »
Anybody know how to find out the actual ink level on the Ricoh 3300?
Re: Exact ink level
weigh the cartridges when new, and then before and after each job, and then when empty
gorgall2
Re: Exact ink level
Post by gorgall2 »
They do not recommend removing cartridges except for replacement. This method is easier http://www.youtube.com/watch?v=lSMHoMXXy6Y
Ian M
Re: Exact ink level
Post by Ian M »
mugstar;48315 wrote:Anybody know how to find out the actual ink level on the Ricoh 3300?
Must admit that is one of the plus points of a CISS as you can see exactly what you have in there at all times. On top of this you can pull out & replace refillable cartridges on the Brother printers because, if you put a part full one back it asks you is it is a new cartridge or a part used one.
mugstar
Re: Exact ink level
Post by mugstar »
Good old Conde! Thank you Gorgall.
