new 6oz blanket
bigj2552
Re: new 6oz blanket
Post by bigj2552 »
price about now is £42 incl vat from martin......
what else does this blanket cover ?
will be doing water bottles & the kids water bottles ( both BMS )
and also the soap & toothbrush holders ( also BMS ) .
What else would this £42 blanket be used for in my df1 mug press ? - or is that it ?:confused:
Re: new 6oz blanket
Scotty@BMS
Re: new 6oz blanket
Post by Scotty@BMS »
Also Sparta mugs, Fine China cups, Espresso cups...
bigj2552
Re: new 6oz blanket
Post by bigj2552 »
cheers guys - worth the £42 quid then - thanks ! :wink:
Re: new 6oz blanket
I had my from coralgraph for £25 delivered :rolleyes:
bigj2552
Re: new 6oz blanket
Post by bigj2552 »
Paul;48054 wrote:I had my from coralgraph for £25 delivered :rolleyes:
eh ? - i looked on his site - couldnt find any mug blankets ?? :confused:
bigj2552
Re: new 6oz blanket
Post by bigj2552 »
just used the dam search button over there :rolleyes:..aye, your right enough mr Paul lol :biggrin:
but are they not just for HIS mug press's ?
or would they fit the BMS m1 mug press, or whatever its called ?
edit -
they all have the same discription !!! - which one is the 6oz blanket ??????
Re: new 6oz blanket
Ask them. have you got for holes on each side of your blanket? also if you have 4 pin connector then it will fit. i know as i got my from them.
bigj2552
Re: new 6oz blanket
Post by bigj2552 »
Paul;48064 wrote:Ask them. have you got for holes on each side of your blanket? also if you have 4 pin connector then it will fit. i know as i got my from them.
check with the four pin connector
and
[ATTACH=CONFIG]1060[/ATTACH]
vB_ID:1060
vB_ID:1060
Re: new 6oz blanket
look same as mine. now check your cable if it has 4 pins.
