Ricoh gxe3300n ... I would like some help please :)
PersonalizedGiftz
Re: Ricoh gxe3300n ... I would like some help please :)
Post by PersonalizedGiftz »
I am about to set this up .. do i just use the install disc that came with the printer then put in the sublimation inks? Or do i need to install a powerdriver etc?
PersonalizedGiftz;48006 wrote:I am about to set this up .. do i just use the install disc that came with the printer then put in the sublimation inks? Or do i need to install a powerdriver etc?
Yes you install from the disc AND you download PowerDriver to install also.
