Cushion Help..
Re: Cushion Help..
Hi..i usually use Martins satin cushions but had to get a few from another supplier till bms had them back in stock..these ones have the zip at the bottom but i am getting a yellow shadowing from the image coming through on the underside after i press them..? I was pressing at 200 for 75sec medium-firm pressure..can anyone tell me what there times etc are incase these are a different material and i need to change something..Thanks
Re: Cushion Help..
We've lots in stock again now!
Have you tried putting a sheet of silicon paper between the layers to stop bleed through? Normally our press temp/ time is 190 for about 50-60 seconds.
Re: Cushion Help..
bms wrote:We've lots in stock again now!
Thanks Martin..will try and will get a order in Monday as never had any problems with yours at all..
