Sublimation ink for a epson sx125
mjcb
Re: Sublimation ink for a epson sx125
Post by mjcb »
hi can anyone help where can i get Sublimation ink for a epson sx125 {im in the uk} THANKS
You'll find a list of UK Suppliers here:
http://www.dyesubforum.co.uk/vbforum/showthread.php?104-UK-Suppliers
You'll need refil carts and also a custom made profile to use that printer for sublimation. Artainium inks would be your best bet.
Welcome to the forum :smile:
mjcb;47249 wrote:hi can anyone help where can i get Sublimation ink for a epson sx125 {im in the uk} THANKS
As Justin has said you'll need to get the inks. A set of 4 colours of Artainium is going to cost around £240 inc vat then there is the cost of the refill carts and a custom profile and then you're still using an 'unsupported' printer although some have used this one successfully (others not I have to say). For similar money - perhaps a little more, you can get yourself a new Ricoh printer with sublimation ink and PowerDriver and full support from the main sublimation suppliers (we are one, but there are others). If you're new to sublimation then there is a lot less hassle in going for a supported solution, but if you're interested in cutting your teeth with sublimation and dinging it more of the DIY route then the SX125 will give you experience.
