Does anyone use this coralgraph press?
Re: Does anyone use this coralgraph press?
http://www.ebay.co.uk/itm/Coral-2-Mug-S ... 564a23ae04
Im in the market for a new one and this fits my budget, i thought some of here might have it and any thoughts on it?
Cheers
Dave
Cheers
Dave
sorry bud - dunno about that one but -
i bought the below from BMS over the last month and i,m glad to report, it works absolutly great
easy to use, but it is a couple of quid over your budget
http://www.printerowners.co.uk/hardware ... -press.htm
- mrs maggot
i have one like this, as well as the one that i won from BMS - i love the simplicity of this press, i have had it a few years now, and it is great, cant say it was originally from them as it was not, but it looks generically the same it presses elgrande and std mugs, without having to change anything
My mug press is just the same but, I didn't get it from Coralgraph. Like Laura I've had mine for a few years now & it has been worth its weight in gold.
Yup, we have a Corel 2 (and Corel 4). Both presses are excellent and highly recommended.
gavtheoldskater
personally, with the way that coralgraph are treating me at present over a faulty mug press i would'nt touch them.
That is the true test of a company - how do they handle things when they go wrong? I've bought many things from Coralgraph and never yet had a problem with anything, so I'm not in a position to comment on their aftersales service.gavtheoldskater;48030 wrote:personally, with the way that coralgraph are treating me at present over a faulty mug press i would'nt touch them.
All companies have the occasional customer complaint they do not handle well enough. I bought a heat press from UKCutter a while ago, and within minutes of ordering it I heard of someone who had had lots of problems with them and a faulty heat press and them refusing to refund on it. I was quite worried after hearing this, especially when my heat press arrived the next day and it too was faulty (kept tripping the electrics once it got to 90 degrees). The very next day however I had my faulty one collected and replacement delivered by the same driver and the new one has been perfect.
I had few things fo wrong with coralgraph... brocken mugs, goods never received etc... little things. All was sorted within 48h each time. Cant fault them.
You were lucky Paul I wasn't & would never buy off them again.Paul;48067 wrote:I had few things fo wrong with coralgraph... brocken mugs, goods never received etc... little things. All was sorted within 48h each time. Cant fault them.
fair enough...Ian M;48068 wrote:You were lucky Paul I wasn't & would never buy off them again.
I only saing that I received great customer support every time. but if you was different then cant blame you...
