i keep needing small amounts of vinyl stickers, and also the stuff you can iron onto materials (you can see how little i know here) and i'm beginning to wonder if its time to look into getting a very basic cheap set up - either new or used.
can anyone tell me or give me any advice what sort of cutter i should be looking for and what i would need? thanks
idiots guide to basic cutters?
gavtheoldskater
Re: idiots guide to basic cutters?
If you need some simple vinyl stickers of not ver big siz then look on craft robo. You can pick one up for less then £100.
gavtheoldskater
yes it will just be small stuff, at most no bigger than a4 i would think. generally around 18cm long lettering.
gavtheoldskater
yep, after a bit of time on google and trawling through threads it looks like a craft c3330-20 or similar is the way to go, thanks. wanted ad and ebay search coming up.
if this is only lettering stuff then 1st CR will be perfect. I have seen one for about £50 not long time ago.
