I have flexisign 8.5 and trying to cut images out but cannot figure out how to achieve this.
if i import an object i click outline but get a rectangle around the image and not a line that follows the outer of the image.
Also i have tried to vectorise the image when i do it has auto plotted the outline but i cannot adjust this as i would like to bring in a bit to avoid any white marks.
Next i want to insert plot lines to send to my printer but cannot find how to do this.
Anyone explain in simple terms please thanks.
contour cutting in flexi
- mrs maggot
Re: contour cutting in flexi
on you tube there are loads and loads of instructional videos, might be worth checking, what type of image are you importing ?? normally there will be a rectangle around the image that you load, and then weed. might also be worth checking uksign forum, or one of the others where flexi is discussed more frequently (on here the vinyl section is smaller and not as busy, as its mostly for dye sub)
I think you tring to cut jpg
make sure your image is made curves. O tried to contoir cut va flexi 8,5 but could not doit. Flexi 10 can do that.
There are vids on u tube but for 8.1 not 8.5, if i type text in i get the option to change outline color and it gives me a contour line to adjust, but if i import a pic a vectorised on it already has plotted lines around it but i cannot adjust them or insert plot marks befor i send to print
- mrs maggot
you might need to ungroup the image ?? i work in corel and them inport in the finished item, so not too sure, like i say try the sign forums, as they deal a lot more with cutters
