drivers for liyu
Re: drivers for liyu
I have a liyu cutter sc631e with a copy of flexi8 starter, i have bought flexisignpro v8.1 but when i try to set up my cutter is not listed and nor is my printer has anyone idesa? have contacted manufacture of plotter and software but no contact yet.
- mrs maggot
as its a generic cutter, you should find that a similar cutter (ie the one its a chinese copy of) will work, try P cut if its listed or any cutter that has the 631 on it when its listed.
- WorthDoingRight
Have you tried Signzworld in Birmingham? They are I believe the European Liyu distributors. They provide telephone support which you can access via the following number:
0121 783 8357
Maybe worth trying if you havent already.
0121 783 8357
- mrs maggot
also t shirt forum has a section on different cutters, and a quick google is showing a lot of details (but be warned - t shirt forums like you to read posts first and get your answers from there, rather than post question which have already been answered)
have tried them only support 8.8 and 10 suggest google looking like sofware is a waste of money have to buy version 10
- mrs maggot
plugy where did you buy all the equipment from ?? can they not help at all ?? last time i bought a cutter second hand i took my laptop with me and got the guy to install it so i knew it worked with my laptop
I think i have all drivers for most chinese cutters somwere... I will have a look and see if i got one that you need.
