Custom polypropylene/PVC/clear plastic boxes
Help in finding new products.
Re: Custom polypropylene/PVC/clear plastic boxes
Hi,
We're needing to source some custom clear plastic boxes, like these mug boxes http://www.printerowners.co.uk/sublimat ... r-mugs.htm from BMS. But we need different sizes making up - wanting them for the glass chopping boards, and then for sets of The Transfer Press' square glass coasters.
For the glass coasters, we'd like them layed out flat in a set of six, so a box which is 20cm x 30cm and not very deep - not sure where to look for something off the shelf, or made to order, Google not turning up much, so wondered if any of you knew of anywhere?
Tim
pisquee;46579 wrote:Hi,
Tim
Do they need to be acetate or cardboard with a cut out? The factories that do acetate ones will probably have minimum orders of a few thousand. If you do it with cardboard then this would probably be cheaper - or you could get your self a small cutter like the Craft ROBO or Cameo and cut these yourself. There is a thread on here somewhere about custom boxes.
Minimum orders aren't necessarily a problem, just needing to know who to approach really. Would prefer complete clear plastic boxes, as the design will spread over the 6 coasters, so we'd like the box to work as a display.
Companies I've found so far seem to be more storage box type clear plastic rather than thinner display/retail box stuff.
Sand & Sea
Post by Sand & Sea »
Have you tried looking at the bag and box man. They do quite a lot of different packaging, and if quantity is not an issue, you may be able to get custom size made up.:smile:
Thanks for the lead to bag and box man - have asked for quotes
