my pictures are dull and faded when i tried to heat press a mug
Re: my pictures are dull and faded when i tried to heat press a mug
My first print resulted in disaster, im trying to heat press a mug, Epson print set to photo best and mat paper, 240degrees at 4o seconds what have i done wrong?
The picture came out really dull and faint
lower the temp to 180 degrees and up your time 180 seconds.
Make sure the press is set on Centigrade.
Jack
Jack
I have now set press to 240 and for 180 seconds and still the prints are dull.JackB;46528 wrote:Make sure the press is set on Centigrade.
Jack
When they are printed they are dull, maybe here lies the problem.
I am useing heat sub paper with epson p50, i have tried setting the paper to matt and photglossy, set to best photo and still very dull when printing am now stumped.
Lower the temperature.Reg;46527 wrote:lower the temp to 180 degrees and up your time 180 seconds.
temp is way to high bud - 180-190c for 180sec - and yes, make sure its in centigrade
refer to your manual
what kind of paper are you using bud ?
and -
are you printing on the right side of the paper ???????
and -
...and is color enhance off?
paper is kalon temp set at 180 degrees time 180 seconds, image printed via photoshop, printer set to photo, plain paper, printing the white side.
They will be dull on the paper until heat pressed.plugy;46532 wrote:When they are printed they are dull, maybe here lies the problem.
Is photoshop menages colorsor printer???
