Hot Flex - Looking for a new Supplier
nik_decalarama
Re: Hot Flex - Looking for a new Supplier
Post by nik_decalarama »
Does anyone know of any cheap suppliers of hot flex? I potentially have a huge bag pressing job coming up (if I can quote a good price) so need to obtain the best possible price on materials. I currently use MDP and I'm struggling to find anyone cheaper - MDP can do hot flex for £4.45 (ex VAT) per metre (25metre log). Anyone know of any suppliers that can do it for less?
Will start a new thread with this for you.
letsgo
Post by letsgo »
Hi,
Have l look at target transfers they have some flex going at £3.85 a metre ,not used myself this has been reduced from £6 a metre think they must be phasing it out for a new line of flex.
Gary
nik_decalarama
Thanks Justin, I should have done that myself instead of reviving an old post.
cheers Gary, I'll take a look. Any reduction is great as it could help secure the job.
Earl Smith
Post by Earl Smith »
http://www.targettransfers.com/dynam...epartment=CL01
Not trying to put you off this material but if you have fine detail or small 1cm text (or smaller) to do , be careful.
The non sticky carrier is a problem.
nik_decalarama
Thanks for the headsup, not to keen on using non sticky carrier paper myself but the job I would need it for has nothing too small.
logobear
Post by logobear »
the new 123flex from the magic touch is cheaper and very easy to use, - 3 second press hot peel!
nik_decalarama
Just had a quick look at magic touch's website, that 123flex seems to good to be true!
mrs maggot
Post by mrs maggot »
ive moved over to 123flex for all my t shirt work, had my first odd moment, a huge join part way through the roll - and of course had to be part way through a cutting job roll was loaded onto the carrier so did not notice, and the join was right in the middle urrrghhhhh, never had a join in a whole roll before
