Sublimating coasters!
North guy
Re: Sublimating coasters!
Post by North guy »
Hi guys, just bought some coasters from bms but having problems!
For some reason they just won't work.
I bake for 60 secs at 90 degs like it advises but it just comes out really light as if the ink isn't transferring.
Any ideas?
Griff
mastercueman
Post by mastercueman »
90 degrees? I'd try nearer 190 degrees! I do mine at 185 degrees for 70 seconds.
AdamB
Post by AdamB »
I do wooden placemats and coasters at 200 degrees for 60 secs - should probably be slightly lower in temp but I found doing them this way I avoid having to pre-press toget rid of any moisture and as my old mum says "if it aint broke - don't fix it".
AdamB
Post by AdamB »
Oh - and make sure the protective film is removed (if it's there).
smitch6
Post by smitch6 »
i always do mine at 200c for 60 secs as well
and they are BMS's coasters i use the nice shiny hardwood ones
North guy
Post by North guy »
oooops sorry meant i press at 190 for 60 secs, it just seem to be transfering the ink!
i thought it must be a protective film but i cant see that it has one
jennywren
Post by jennywren »
They do, just keep picking at the corner and it comes off, then you'll find a difference. I use a stitch picker to get at it, but gently or wise you might scratch the coaster
if they are wooden ones then they dont have a film on. as far as i can remember...
jennywren
Post by jennywren »
bassqee
Post by bassqee »
USually when i have forgotten to take of the plastic once pressed its stuck too the paper, double check your paper for it.
Users browsing this forum: Ahrefs [Bot] and 2 guests
