new printer???? any printer???
Billy
Re: new printer???? any printer???
Post by Billy »
hi guys just got a quick question for yous, my epson s21 packed in today :frown: but i have an epson sx425w ...... if i have a ciss for it can i yous it to print my sublimation images for my mugs??? if so could i do it with pretty much any printer???
Billy
Post by Billy »
needing a quick reply plz peeps as im just about to buy the ciss from ebay .....plz
bassqee
Post by bassqee »
I would assume so since it has the micro peizo tech in it. but better having someone who knows better confirm.
Yes, any Epson inkjet printer can use sublimation inks. As with any printer being used for sublimation you will need an ICC to get the right colours from the inks. This is sometimes provided by the ink manufacturer or reseller, and sometimes you have to get a custom one made.
Billy
Post by Billy »
cheera guys , already got an icc profile for the inks just needed to know if i could use the printer , much appreciated troops
If you want to use your existing icc then you need same printer that wa used to create icc. Otherwos it wont work.
As Paul said, each different printer model will need a different ICC (unless they are technically the same printer, but cosmetically different with a new model number!)
JSR
Post by JSR »
Billy;44605 wrote:needing a quick reply plz peeps as im just about to buy the ciss from ebay .....plz
You could have got a quick reply by searching the forum: http://www.dyesubforum.co.uk/vbforum/sh ... ch-Printer
That tells you all about which printers you can use, why you can use them, and much more.
