Cool spots on heat plate
gadgetsboy
Re: Cool spots on heat plate
Post by gadgetsboy »
What causes cool spots on the heat plate? This is a problem that appears to be intermittent sometime when i press vinyl or flock i get a spot near the top left corner that doesnt stick to the garment as though it hasnt been pressed i then have to move the garment and repress and then as you can imagine i then get to clean the adhesive from the rest of the garment. I then turn off the heat press let it cool and switch it back on and 9/10 times its perfect again
Any ideas anyone? is this just the by-product of cheap chinese machines?
purpledragon
Post by purpledragon »
Think you may have answered your own question
Andrew
Post by Andrew »
Probably just a dodgy press. I have a GeoKnight which I often get problems with so not just cheaper chinese models. My Adkins was great until it has now developed a heater fault which stops it holding temp. It has run nearly 8 hrs a day, 5 days a week for 4 years though and I am sure I'll get it back up and running as well.
gadgetsboy
Contacted the vendor who informs me he has seen the problem before and it can be solved very easily and cheaply I am awaiting the email with the fix instructions. i'll keep you posted
purpledragon
call me suspicious but couldnt he give you the fix the same time he told you he'd heard of the problem before?
cold spots are generally due to certain areas of the heating eliment not working as well as the rest of the platern, a reasonable fix i would think is a new platern in otherwords a new press.
Sorry to be the bearer of bad news. Though it does depend how bad it is i have a cold spot on one of my presses but it doesnt really affect me to badly.
Brett
gadgetsboy
purpledragon wrote:call me suspicious but couldnt he give you the fix the same time he told you he'd heard of the problem before? Brett
You may be right he sent me a pdf with platern cleaning instructions. when i rang today he wasnt available
purpledragon
well name and shame them then, its about time suppliers faced upto some of the problems we have i suspect martin (BMS) has taken quite a bit of buisness from fly by night suppliers simply because he's available and eager to assist with problems.
still waiting for the fiver he owes me for all positive comments make about him
Brett
Fiver was sent in the post ages ago Brett - sorry did it get lost ;)
I've not heard of curing cool/ cold spots by cleaning a platen before but I'll have to remember that one for the future :? . I agree with the previous posts that it's probably something to do with the heating circuit inside the platen. They're usually formed like a snake - up/ down/ curl around so a cool spot could occur on the corners or between the heating circuit if the wires have not been laid very well. Either the platen will heat up or it won't heat at all if the circuit is one complete heating wire inside the platen
purpledragon
all i got was a white bit of paper you need to use artanium ink next time you print money martin
Couldn't possibly do that - do you know the cost of Artainium ink :shock: ? :)
