Door plates
Help in finding new products.
phoenixalpha
Re: Door plates
Post by phoenixalpha »
Does anyone know of a decent (and cheap) source for aluminium door plates with pre drilled holes, screws and screw caps?
Re: Door plates
phoenixalpha;43605 wrote:Does anyone know of a decent (and cheap) source for aluminium door plates with pre drilled holes, screws and screw caps?
We can cut any shape (square/ rectangle) with rounded edges and holes in corners. Don't do the screws and screw caps though.
Re: Door plates
phoenixalpha
Re: Door plates
Doesnt need to be for sublimation though.
phoenixalpha
Re: Door plates
Can anyone give me a price for (or know of somewhere that does) A5 aluminium sheets with rounded corners at least 1.5mm thick and two screw holes?
Dezignwar
Re: Door plates
Post by Dezignwar »
I may be able to help but it would be after the weekend when i have a confirmed answer and price. where i work full time we have a punch machine which is capable of doing up to 6mm alloy.. i have some of my own 1.5mm white alloy that i could pos punch on it to any shape and size with any holes required.. if thats any help.
