Sublimation on polyester
derekwolves
Re: Sublimation on polyester
Post by derekwolves »
i have been asked to print on to a mat with is made of polyester (white )
would i be able to sublimate the material ??????
just putting that out there if any one has done this
have asked the customer to get me a test mat:rolleyes:
If it's 100% polyester surface, in principal yes. Do you know if the mat has anything inside? i.e. something that might melt! Always good to get a test bank to work with :-)
derekwolves
[h=3]Product Description[/h] This is a blank playmat measuring 24” x 14” (plus or minus 0.25") with a approximate thickness of 1/16”. Handy, this custom playmat can be rolled or folded to fit in backpacks or just simply hand-carried. It is a perfect gift item for your friends, family, and other fellow duelists! Not only can this playmat accommodate your most expensive cards, it can also be used as a mouse/keyboard pad.
derekwolves
[h=1]Blank White Playmat 24"x14"x1/16"
[/h]
  • Image
(Image 1 of 1)
Could be like mousemat material, where did you get the description from? Do you have a printer/press large enough to do this item bearing in mind you need to go slightly larger?
derekwolves
and has any one got a printer that could print this big ???????????
derekwolves;43304 wrote:and has any one got a printer that could print this big ???????????
Several printers around that will do this size, but fewer flat bed presses of this size. You're moving into custom made size presses or roller presses - I do know of a customer who has a flat bed press that will do 44" wide prints, but these are few and far between.
derekwolves
no i have max 14"x14" i am thinking on a bar runner for the customer on on the same size but mite work for him. its for on online game card mat and the art work is very detailed.
derekwolves
Thanks Martin i going to talk to my customer about the change of size.
