Compared with petrol
Reg
Re: Compared with petrol
Post by Reg »
THIS WILL MAKE YOU THINK !
Compared with Petrol......
Think a gallon of petrol is expensive?
This makes one think, and also puts things in perspective.
Apple Juice 16 oz £1.29 ........... £10.32 per gallon.
Lipton Ice Tea 16 oz £1.19 ........... £9.52 per gallon.
Ocean Spray 16 oz £1.25 ............ £10.00 per gallon.
Brake Fluid 12 oz £3.15 ............. £33.60 per gallon.
Vick’s Nyquil 6 oz £8.35 ........ £178..13 per gallon.
Pepto Bismol 4 oz £3.85 ........... £123.20 per gallon.
Tippex 7 oz £1.39 ........................... £25.42 per gallon.
And this is the REAL KICKER.
Evian water 9 oz £1.49 ……….. £21.19 per gallon.
£21.19 for WATER and the buyers don’t even know the source.
(Evian spelled backwards is Naive.)
You don’t even want to compare it with perfume or after shave.
Ever wonder why printers are so cheap?
So they have you hooked for the ink.
Someone calculated the cost of the ink at .....
(you won’t believe it .... but it is true ........)
£5,200 per gal ... (five thousand two hundred pounds)
So, the next time you’re at the pump,
be glad your car doesn’t run on water,
or Tippex, Pepto Bismol, Nyquil or, God forbid,
Printer Ink!
Just a little humour to help ease the pain of your next trip to the petrol pump.
And
If you don’t pass this along to at least one person, your exhaust will fall off!!
1 Imperial/UK gallon = 4.5 litres = 157.5 fluid ounces
1 USA gallon = 3.8 litres = 133 fluid ounces
(1 litre = 35 fluid ounces)
Evian Water
= 84p for 2 litres (mysupermarket.co.uk)
= 42p for 1 litre
= £1.89 per imperial/UK gallon
= £1.60 per USA gallon
Sawgrass sublimation ink
= £150 for 1 litre (BMS)
= £675 per imperial/UK gallon
= £570 per USA gallon
Epson UltraChrome Ink
= £84.80 for 220ml (Epson website)
= £0.39 for 1ml
= £390 for 1 litre
= £1755 per imperial/UK gallon
= £1482 per USA gallon
Non-Sawgrass bulk ink
... nah, I'll stop there. ;-)
Renniwano
Post by Renniwano »
My exhaust has a huge hole in it lol.. wish it would have just fallen off instead.. lol
Definately stealing that one and facebooking it..
