removable wall vinyl
Re: removable wall vinyl
Any one know wher in uk i can get those?
letsgo
Post by letsgo »
Paul,
Try the vinyl corporation or spandex,also was it the digital type for printing or just plain colour.
Gary
Renniwano
Post by Renniwano »
If it's not for printing on.. and just plain colour, MDP now do an Aslan Matt removable vinyl..
chongsta
Post by chongsta »
Hi paul.
Yes there's a dedicated material for this! its http://www.phototex.co.uk/
I searched for ages to find proper wall vinyl and this is what you want. Its pricey!!! £300+vat for 30metres! but if you want to print proper digital images then this is the daddy.
The people selling wall stickers on ebay are using normal car vinyl (well most of them), this WILL take paint off walls as i found out to my mothers anger :)
This material is removable upto 200 times, its not a vinyl as we know it, its more like a textile but its fully printable in large format printers with a minimum size of 30". I'ts a bit of a bugger to cut with 45degree blades but i was advised to goto 30degree for a sharper cut - which worked a treat. You can then use a low-tack application paper to put it on a wall or if the design is more of a block, you could just peel it off and then apply it to the wall.
Contact Robert Holding > sales@landoruk.com < really nice guy and will help you lots.
He'll send you a sample image for you to try but its only an A4 with a ready made print/cut, but you'll get to see that this is what you need. If you're doing this on eBay you need to stress that this is the proper stuff (and dont give the Landor name away :) *our secret*)
There's a thread somewhere here that i posted which was to offer this service to dyesub members, but when i did the costings compared to what ebay sellers were doing them for, it was useless! i couldnt do them cheap enough to sell B2B and then for the member to sell on, this is something you have to do by yourself with your own printer/cutter.
Hope that helps mate
Dave
p.s. i tried lots of vinyls from different companies and in all fairness none of the companies said that they stood by it if it was for use on walls, at least they were telling the truth. This stuff is designed specifically for wall designs, removable and re-applyable upto 200 times! start saving your cash paul :P
RogerC
Post by RogerC »
Try talking to Grafityp I think it was them showing something for walls etc at the Sign & Digital show last year.
