Ricoh GX7000 - Life Expectancy
michaelc
Re: Ricoh GX7000 - Life Expectancy
Post by michaelc »
What sort of life can be expected from the Ricoh GX7000? Just curious, really. I have 15,000 prints on mine, mostly just twin logos on mugs, I guess about 8% of A4.
Martin cull
Post by Martin cull »
Mine was 18 months old when it died.... It was a low use machine and ran great on Ricoh branded inks. First time we used sawgrass label inks within a month it was dead.... Standard power board failure from what we have seen on other forums.
No spare parts available, no support from Xpres, no help from sawgrass..... Expensive doorstop now.
Martin cull;43868 wrote:Mine was 18 months old when it died.... It was a low use machine and ran great on Ricoh branded inks. First time we used sawgrass label inks within a month it was dead.... Standard power board failure from what we have seen on other forums.
I'd suggest you follow this up with Xpres as there is support available if you want to continue to use the A4 or A3 Ricoh platform. If out of warranty then you will get some financial assistance towards a new Ricoh printer and Subli-jetR inks.
DaveM
Post by DaveM »
Mine has died again today, the 2nd GX7000 :-(
First was replaced by BMS, and both with very low usage as I do embroidery most
of the time.
Is there still any assistance to help repair/replace it ?
Dave
Ian M
Post by Ian M »
Might be a good question to ask Sawgrass through Justin.
DaveM
Post by DaveM »
Ian M;48333 wrote:Might be a good question to ask Sawgrass through Justin.
