Re: Sublimation Magnetic Sheets
Posted: 03 Feb 2010, 14:17
by joconnell
I have received an enquiry for magnetic business cards. Does anyone know of suppliers of sublimation magnetic sheets.
Many Thanks,
James
Posted: 03 Feb 2010, 14:59
by accdave
Posted: 03 Feb 2010, 20:44
by bms
Posted: 04 Feb 2010, 09:45
by joconnell
Martin,
I was looking for large sheets that I would cut myself. The order is for 500.
I have been in touch with Transfer Press, they have none in stock at the moment but chasing it up for me.
Thanks,
James
Posted: 04 Feb 2010, 12:42
by bms
Okay. We sell it in larger sheets for you to cut yourself - either 300mm x 600mm or 200mm x 300mm.
http://www.printerowners.co.uk/sublimation/508/magnetic-sheet.htm
Posted: 05 Feb 2010, 11:34
by joconnell
Martin,
Thanks for that but thetransferpress have come up with what I need. Will keep you in mind in the future.
Thanks again,
James
Posted: 08 Feb 2010, 21:35
by joconnell
Does anyone have experience of making magnetic business cards as I am interesred in what time,temperature and pressure you used.
Many Thanks,
James
Posted: 09 Feb 2010, 08:00
by bms
For our's we recommend:
Pressing temp 195 degrees C and press for 40- 50 seconds with light/ medium pressure. This product can be pressed upside down with the product sandwiched between 2 pieces of paper.
