Sublimation Magnetic Sheets
joconnell
Re: Sublimation Magnetic Sheets
Post by joconnell »
I have received an enquiry for magnetic business cards. Does anyone know of suppliers of sublimation magnetic sheets.
Many Thanks,
James
joconnell
Post by joconnell »
Martin,
I was looking for large sheets that I would cut myself. The order is for 500.
I have been in touch with Transfer Press, they have none in stock at the moment but chasing it up for me.
Thanks,
James
Okay. We sell it in larger sheets for you to cut yourself - either 300mm x 600mm or 200mm x 300mm.
http://www.printerowners.co.uk/sublimation/508/magnetic-sheet.htm
joconnell
Post by joconnell »
Martin,
Thanks for that but thetransferpress have come up with what I need. Will keep you in mind in the future.
Thanks again,
James
joconnell
Post by joconnell »
Does anyone have experience of making magnetic business cards as I am interesred in what time,temperature and pressure you used.
Many Thanks,
James
For our's we recommend:
Pressing temp 195 degrees C and press for 40- 50 seconds with light/ medium pressure. This product can be pressed upside down with the product sandwiched between 2 pieces of paper.
