Numbers on Team shirts?
Stitch Up
Re: Numbers on Team shirts?
Post by Stitch Up »
Hi guys
Just been asked to supply the numbers 1 to 22 and heat press to rugby shirts supplied by the customer.
Couple of questions:
1. Is it cheaper to buy the vinyl and cut rather than buying ready made from someone like Target?
2. What font is usually used for the numbers?
3. What is the standard height of each number?
Cheers
John
purpledragon
Post by purpledragon »
John i found it easier to buy the numbers from somewhere like target transfers and they are pretty good too
Id have a little look round the net see what the latest number styles rugby teams are using nowadays then find the closest match on target
Brett
Stitch Up
Post by Stitch Up »
I must admit, I did check with Target and the cost was surprisingly high!
I don't have a clue what font is used, Angie said she thought they'd said New England was standard.
Cheers
John
accdave
Post by accdave »
xpres have a very limited choice which are cheaper than Target. Bware though, they are cut with a very thin line on the outer, and can be a real pain when peeling off :roll:
Jusr realised as well I think Xpres have a Corel draw file with the various number templates. If you don't find them I can send them to you.
Stitch Up
Post by Stitch Up »
Thanks Dave, any chance you could send them to me?
My email is: john (at) stitch-up (dot) biz
John
accdave
Post by accdave »
No problem, will do it later when I log on to the other PC :D
