Craft Robo cc330 and Subli Flock and registration marks
Mugdesigns4u
Re: Craft Robo cc330 and Subli Flock and registration marks
Post by Mugdesigns4u »
Hi everyone, I hope you can help. I want to print and cut a logo on to Subli Flock. What do I do about the registration marks? I have spoken to Graphtec who have been very helpful but I have not really answered the question. Am I right in thinking that I need to print the registration marks in mirror so that when I sublimate the image on to the flock that the image and reg marks are the correct way around.
Is there a simple way of doing this using Corel Draw x4, or am I being a bit thick!!!!!
Earl Smith
Post by Earl Smith »
Print the design with the three registration marks in reverse onto subi paper, then press onto the flock. I dont know the Craft Robo but I presume from your post that it has optical recognition. It will see the registration marks and then cut the pre loaded vector lines which you drew in X4.
Earl
Mugdesigns4u
Thanks for that I will try it :-)
Mugdesigns4u;38981 wrote:Hi everyone, I hope you can help. I want to print and cut a logo on to Subli Flock. What do I do about the registration marks? I have spoken to Graphtec who have been very helpful but I have not really answered the question. Am I right in thinking that I need to print the registration marks in mirror so that when I sublimate the image on to the flock that the image and reg marks are the correct way around.
Why not cut your subliflock first (in reverse) then press your image into the cut piece?
Mugdesigns4u
Thanks Martin
That is actually what I have done, however I was trying to be a smart A**e and wanted to know how to do it the registration mark way. But thank you so much for taking the time to get back to me.
Earl Smith
A little confession as well. I do it the way Martin said as the optical recognition way is a PITA.
Earl.
AdamB
Post by AdamB »
bms;39022 wrote:Why not cut your subliflock first (in reverse) then press your image into the cut piece?
Earl Smith;39065 wrote:A little confession as well. I do it the way Martin said as the optical recognition way is a PITA.
Earl.
Is it hard to line up the print to the cut?
I've not tried it - just curious ......
Earl Smith
If you look on youtube you will see videos on how to do it. No it is not difficult, you just have to line up the two registration points on the front.
But Id stick to the way Martin said, its easier.
AdamB;39079 wrote:Is it hard to line up the print to the cut?
If you make your image, say 1mm larger than the piece then it's easy to position the cut piece on the image, hold in place by tape, turn over and press. Simples :)
accdave
Post by accdave »
bms;39142 wrote:Simples :)
Unless you are cutting circles ( see my previous post on this issue ) :biggrin:
