Thermal travel mugs from Coralgraph
Re: Thermal travel mugs from Coralgraph
Hi all
I'm in need of some silver thermal travel mugs. I've tried my usual supplier (BMS) and they're currently out of stock.
I see Coralgraph have them for £3.49 each including delivery (or £25.99 for 12 including delivery - £2.16 each). Now, this is a lot cheaper than BMS/Listawood (£3.75 plus VAT plus delivery), so I'm wondering what they are like.
Any experience/advice/comments gratefully received!
Cheers
Barry
Cheers
Barry
i didnt try coralgraph ones but is not that BMS and coralgraph getting they stock from this same source??
btw... how many do you need? as I may have spare couple in here that i dont need for now.
I've not tried either but it strikes me that, at £3.49 all-in, it'd be worth getting one just to see if it's any good to you.
Don't think so!Paul;38977 wrote:i didnt try coralgraph ones but is not that BMS and coralgraph getting they stock from this same source??
no?? only asking as this is what i always thought. but some stuff you got similar maybe that's why...
China/ Far East is a big place with hundreds of different manufacturers of productsPaul;39023 wrote:no?? only asking as this is what i always thought. but some stuff you got similar maybe that's why...
- Has thanked: 11 times
- Been thanked: 9 times
Ask Henry to send you a sample or buy a couple from Paul, give them a try
i've used the ones from coralgraph and can't fault them at all, great quality and finished product looks great. I would recommend them
Matthew
I assume travel mugs use exactly the same process for printing as ceramic mugs?
Is there any reason why it seems to be the same style of travel mug offered by most suppliers? Does anyone supply, in small quantities, the straight edge mugs. Or are they not suitable for sublimation? Apologise for butting in :rolleyes:
[ATTACH=CONFIG]792[/ATTACH]
- vB_ID:792
- Coloured_Stainless_Steel_Mug.jpg (47.99 KiB) Viewed 28 times
- Coloured_Stainless_Steel_Mug.jpg (48.34 KiB) Viewed 28 times
Shirt Printing Design and Culture teesandhoodies.com
