smug mugs
schizowife
Re: smug mugs
Post by schizowife »
Hi
Has anybody used these 6oz smug mugs from magictouch (or anywhere else for that matter) do they fit in a regular 11oz mug press? Cant tell if they are just shorter or much slimmer as well? If not is there a special press for these? Look great for kids!!!
Re: smug mugs
The child mugs or small mugs (smugs) won't fit in a standard mug press. You will need a thicker blanket or a 6oz blanket to do these. The DF12 mug press will do standard and thinner/ narrower mugs with the separate thicker blanket.
schizowife
Re: smug mugs
Just noticed you do these as well Martin, Do they come with a saucer!? So i can purchased the 6oz mug blanket and use this inside my press yes? or am i having a blonde moment? (apologies to blonde members:redface:)
smitch6
Re: smug mugs
Post by smitch6 »
men prefer blondes tho :rolleyes: hehe (sorry couldn't resist )
Re: smug mugs
yeah steve ;)
my wife is blonde too ;)
regards to blanket it not need to be thicker :) it need to be shorter. i use my 11oz blanket for 11 and 10oz mugs and shorter blanket is from windsor mugs :) works great for caffe cups ;)
Re: smug mugs
schizowife;32685 wrote:Just noticed you do these as well Martin, Do they come with a saucer!? So i can purchased the 6oz mug blanket and use this inside my press yes? or am i having a blonde moment? (apologies to blonde members:redface:)
We do have some saucers for the ceramic child mugs and will have saucers available for the polymer child mugs as well shortly.
You do need a thicker blanket to do the smaller circumference mugs as a standard 11oz/ 10oz blanket will not close around these mugs.
schizowife
Re: smug mugs
and if i buy your 6oz blanket i can plug into my combi heat press and use in the clamp with the 11oz blanket around the 6???? Or does it not work like that!!! And this is not a blonde question this is a working too late after too many pinot grigio's question:rolleyes:
Re: smug mugs
schizowife;32710 wrote:and if i buy your 6oz blanket i can plug into my combi heat press and use in the clamp with the 11oz blanket around the 6???? Or does it not work like that!!! And this is not a blonde question this is a working too late after too many pinot grigio's question:rolleyes:
I assume this isn't our combination press, so I don't know what the fittings are like on your press. Our 6oz blanket fits in the metal sleeve of the mug press - where the 11oz blanket is removed. However, if the connections aren't the same then I can't promise that our blankets will work in your press.
